Viewing Tune History
The Tune History window can be used to view all changes to the current tune file and to compare the current version of the file to any previously saved version.
To open this window, do one of the following:
■ | In the menu bar, select Edit > View Change/History Logs. |
■ | In the toolbar, select the ![]() |
The window has two tabs:
■ | Current Unsaved Changes |
■ | Complete Saved History Logs |
The Current Unsaved Changed tab lists all changes made since the last time the file was saved.
Examining Changed Parameters
To examine the parameters changed since the last save:
1. | Expand the tree to locate the parameter you wish to view. |
2. | Double-click a parameter to view and edit its value. |
Toolbar
The toolbar at the top of this tab includes the following:
Refresh. Update the list to include any new items changed since you opened the window. |
Collapse all items in the list. |
Expand all items in the list. |
Each time you save a tune file, a time stamped record of the changes made since the last save is added to the Complete Saved History Logs tab.
This is useful if you want to compare the file to an earlier version of itself or roll back to an earlier version of the file.
Comparing the Current File to a Previous Version
1. | Select the version of the file to use for the comparison. |
2. | Click ![]() |
See Comparing Two Tune Files for more information on the file compare feature.
Rolling Back to a Previous Version
1. | Select the version of the file to roll back to. |
2. | Click ![]() |
3. | Save the file from the new window. |
To examine the parameters changed in any particular saved version:
1. | Expand the tree under the desired save. You can drill down all the way to the individual changed parameters. |
2. | Double-click a parameter to view its value. |
Toolbar
Open the selected version of the file in a new window. |
Open the selected version of the file as the compare file. |
