File Architecture
Use this to better understand the complexity of VCM Scanners open/save dialogs.
Most files are saved in .xml format to enable outside modification if desired, for advanced users.
Architecture By Function
Stores the active Channel Configuration
Stores the active Channel Display Properties
Stores the active Layout Configuration
Stores the active Layout Display Properties
Stores user Math Parameters
Stores user Transforms
Stores user Preferences
Channels
Reloaded from VCM Scanner.cfg on open
Saved to VCM Scanner.cfg on close
Can be saved/loaded from user saved files
Layout
Architecture By File Type
VCM Suite.cfg
Created by the VCM Scanner/Editor applications only
Shared between VCM Scanner/Editor instances
Application Keys
Unit System
Tuning Path
VCM Scanner.cfg
Created by the VCM Scanner application only
Shared between VCM Scanner instances
Stores Active Channel Configuration
Stores Active Channel Display Properties
Stores Active Layout Configuration
Stores Active Layout Display Properties
Stores User Math Parameters
Stores User Transforms
Stores Application Preferences & Settings
*.Channels.xml
Default Location: \My Documents\HP Tuners\VCM Scanner\Channel Configs\
Created by users only
Stores Parameter ID and Source
Stores Channel Polling Intervals
Stores Channel Transforms
*.ChannelDisplay.xml
Stores Channel Display Fonts and Colors
*.Layouts.xml
Default Location: \My Documents\HP Tuners\VCM Scanner\Layouts\
Architecture By File Type - Gauges
*.Gauges.xml
Default Location: \My Documents\HP Tuners\VCM Scanner\Gauges\
Stores all gauges on the selected display
*.Gauge.xml
Stores a single Gauge
*.GaugeDisplay.xml
Stores Gauge Display Fonts and Colors
Architecture By File Type - Graphs
*.Graphs.xml
Default Location: \My Documents\HP Tuners\VCM Scanner\Graphs\
Stores all graphs on the selected display
*.Table.xml
Stores a single Table
*.GraphDisplay.xml
Stores Graph Display Fonts and Colors
Architecture By File Type - Charts
*.Charts.xml
Default Location: \My Documents\HP Tuners\VCM Scanner\Charts\
Stores all charts on the selected display
*.Chart.xml
*.Series.xml
Stores a single Chart and its associated Series
Stores a single series
*.ChartDisplay.xml
Stores Chart Display Fonts and Colors
