Generating a Log File
Scanned data can be saved to a log file, which can be opened later for further review and analysis. There are two ways to generate such a file:
Configure your interface device for standalone data logging. |
Saving a Live Scan
NOTE: Due to changes in file content, log files saved in VCM Suite version 4.13 (and later) cannot be opened in versions older than 4.13.
Follow these steps to generate a log file from a live scan:
Ensure that your channel setup includes all the parameters you want to capture in the log. See Channels. |
When the scan is complete. Click in the toolbar. |
Enter an appropriate file name and click Save. |
Standalone Data Logging
Standalone data logging allows you to save a log file to the memory of your HP Tuners interface device when the device is not connected to your computer. For the full procedures associated with generating such a log file, see Standalone Data Logging.
In short, however, the steps are as follows:
Connect your interface device to your computer. |
In VCM Scanner, configure your interface for standalone data logging. |
Disconnect your interface device from your computer and connect it to the vehicle. |
Use the buttons on the device to start and stop logging. |
NOTE: The MPVI2 and newer interface devices also support programmed start and stop triggers based on driving events.
Disconnect the device from the vehicle and reconnect to your computer. |
6.
In VCM, Scanner, retrieve the log files from the device. |
