Expression Filtering
Entering an expression in the Function field of the Graph Display Layout Editor sets a condition which must be met for the data to be included in the graph you are configuring.
NOTE: Expression filtering, does increase processing overhead, and may not perform well on slower devices.
Defining the function for a filter follows the same procedure as the expressions for math parameters:
1. | Insert variables that represent that output of the sensors and/or PIDs that will be included in the calculation. |
2. | Add supported math operations to complete the desired calculation. |
The completed function must evaluate to TRUE or FALSE (1 or 0). Each frame of data received will be checked against this function:
■ | If the function evaluates as TRUE (1) for the frame, the data in the frame will be added to the graph. |
■ | If the function evaluates as FALSE (0), the data from the frame will NOT be added to the graph. |
Example
Suppose we want to create a filter that filters out throttle values < or = to 50% as well as the transitions before and after. To accomplish this, we need a filter expression that will return TRUE if ALL of the following conditions are true:
■ | Throttle % > 50 |
■ | Throttle % has been > 50 for 500 milliseconds |
■ | Throttle % will be > 50 for 500 milliseconds |
Part 1 - Throttle % > 50
1. | Click New Variable. The Variable Wizard appears. |
2. | Click the Parameter link. The Parameter Selector window appears. |
3. | Search for throttle position and select (double-click on) the Throttle Position sensor in the Generic Sensors group. |
4. | In the Unit dropdown of the Variable Wizard window, select %. |
5. | Click OK. The filter expression should now show a text representation of the Throttle % variable you just created: |
[50090.156]
6. | For this first part of our expression, we simply need to make sure Throttle % is > 50. So, we just need to add > 50 after our throttle position variable: |
[50090.156] > 50
Part 2 - Throttle % has been > 50 for 500 milliseconds
Now, we need to filter out the transitions before this period. To do that, we can use the average function to verify that the average throttle % has been over 50 for at least 500 ms.
1. | This second condition has to ALSO be true. So, we add AND to our expression. |
[50090.156] > 50 AND
2. | Click New Variable to open the Variable Wizard again. |
3. | Select the same Parameter and Unit that was selected in Part 1. |
4. | In the Special Function box, select Average and enter a Period of 500 ms. |
5. | Click OK. Our expression should now look like this: |
[50090.156] > 50 AND [50090.156.avg(500)]
6. | For this period, the throttle position needs to be over 50%. So, we add > 50 to this part of the expression as well: |
[50090.156] > 50 AND [50090.156.avg(500)] > 50.
Part 3 - Throttle % has been > 50 for 500 milliseconds
Now, we need to filter out the transitions after this period. This requires exactly the same procedure that we used for Part 2. However, we will use -500 ms for the period.
NOTE:
So, we add the following to the end of our expression:
AND [50090.156.avg(-500)] > 50
So, the final expression would look like the following:
([50090.156] > 50) AND ([ 50090.156.avg(500)] > 50) AND ([50090.156.avg(-500)] > 50)
NOTE: We've added parentheses to make the expression more readable. But, this is optional. The expression will work without them.
