Results 1 to 3 of 3
Thread: 2017 Yukon 6.2 Adaptive Cruise not working after speedometer calibration
    Dec 2010
    11
    Used wizard to update parameters for 275/60R20 tires. Wizard updated 3 values, driven and non driven tire diameter and vss tire revs per mile. Dash displays "adaptive cruise control temporarily unavailable" when turning on cruise. Return to stock cruise works fine.
    13,610
    Likely it's something that becomes a mismatch between values between two different systems that work together. But that is just a guess as HP Tuners is only able to flash the PCM/TCM and nothing else.
    I'd live with the speedo being off just slightly to keep the adaptive cruise working.
    Dec 2010
    11
    The mismatch is what I was thinking. Maybe the tcm, which I’ve not licensed?
