Well i have no wideband and don't have anyway to check actual AFR. MY car is basically a stock car, just bolt-ons and a converter. While reading through some of the Blogs by redhardsupra he said HERE
10. "Undo the GM marketing department's lame attempts to keep the LS1 from a F-body lower output than the Corvette. Setting the Power Enrichment table universally to 1.15 results in a much more sane (than the overprotective stock) 12.7:1 air-fuel ratio."
I also noticed that on a preliminary transmission tune FOFF helped me with he changed the stock PE to 1.2 across the board....So whats safe on a stock-bolton car without a WB??
