Results 1 to 10 of 10
Thread: 4L80E swap in NBS 2007 truck
    May 2006
    Bowling Green, KY
    103
    Has anyone done this yet? I was just wondering. I have a 2007 here that the customer put a 4L80 in w/ his 4.8L 1500 2wd and I got it rewired, but I am having problems finding a 4L80 segment ID for this OS: 12614088. Is it even possible?
    Thanks,
    Mike
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,290
    Its not a segment anylonger, gm uses an entirely separate TCM for the newer vehicles.
    May 2006
    Bowling Green, KY
    103
    I realize that, but if I do a write entire with a 4L80E program, won't it recal the TCM? I am trying to find a 4L80 TCM out of a junkyard to swap out with the 4L60E one now in case I can't do a write entire with the segment ID's. I can even do it if I can find a VIN from a 2WD w/ a 4L80E in it. I have a Tech2 to manage that if necessary.
    HP Tuners Support
    (foff667)
    28,290
    Quote Originally Posted by Mike@ADS View Post
    Thats currently your best bet, since we don't license the tcm you wouldn't need to use any more credits doing this.
    May 2006
    Bowling Green, KY
    103
    Ok, got it going finally. It shifts just fine, but that 4l80 sucks alot of power out of a stock 4.8L. That was a pain in the azz.
    Nov 2007
    27
    Why did the customer do the swap? A 4L80E sounds like major overkill for a 4.8L.
    May 2006
    Bowling Green, KY
    103
    No clue. He also has 38's and a 8"-10" (or so) lift to make it look 4wd when it is just a 2wd.
    Nov 2007
    27
    LOL! I truly hope a motor swap is next. My 07 Sierra with a 4.8 is barely strong enough to turn my 33's.
    Glad you got it worked out.
    Apr 2003
    Almost 2000 feet.
    7,876
    As a side note:
    IIRC a Tech2 will write the TCM separately from the ECM.
    So, if you have access to a Tech2 you can put the proper cal in the T42 trans controller if you have the right VIN number.
    Always Support Our Troops!
    May 2006
    Bowling Green, KY
    103
    That's exactly what I found out EC. I used a 2008 Express van 4L80E TCM code and programmed it in with the TechII.
