OK, gonna start off with a thanks to everyone that helps people like me.
I have a 2010 JK with a 2004 Chevy 2500 6.0L (trucknorris cam)/4L80E and the JK 241 (changed input to work with the 4L80E) I have the RPM extreme harness kit. I used the donor truck pedal and tac module and RPM supplied the harness. At WOT HP shows 155%, 0% when its at rest. Needless to say this is causing some issues. I haven't received my wide band yet, it in route. I was trying to get it idling and stuff ahead of time and found this issue. I changed the range to match what the pedal reads but I left everything else at 100% referenced to WOT kinda assumed that changing the range would fix the issue. Does this seem like the right thing to do?
