Results 1 to 17 of 17
Thread: Cammed Ve Ss Manual L98
    Jun 2023
    18
    hi after being at several different shops ive been trying to fix up problems with the help of hjtrbo, i have a freshly rebult cammed ve ss manual l98 if been having problems with rough idle and startup hunts up and down for a while before catching itself heres the latest tune file and logs below if anyone could have a look and see if they could help id really appreiate it and happy to pay for your help ? cammed-ve-ss-manual-troy-oztrack.specialspark6_HJ_v1.hpt
    now hj log v3.hpl new hj v1 log4.hpl
    Advanced Tuner rabbs88's Avatar
    Jan 2023
    NY
    273
    I'm confused, are you trying to fail the MAF and run in speed density? The PID in your log says the MAF is failed but it's definitely not failed correctly in the tune. You should probably put your stock timing tables back in too, those don't look great.
    Your fuel trims don't look too bad though. A touch rich but nothing that would cause your issues
    Jun 2023
    18
    hey mate yeah its maffless tune ive been to 4 different tuners but just have stupid problems
    Jan 2023
    NY
    273
    Try this out. Just failed the MAF properly and returned timing tables back to stock. Post a log when/if you decide to try it
    Jun 2023
    18
    okay mate thanks heaps il give it a log tomorrow
    May 2020
    5
    Give this tune a try, I made some injection timing changes and other small tweaks that may help your idle problem
    MAF Failed + Stock Timing + EOIT.hpt
    If you ain?t first you?re last
    Aug 2006
    5BA8
    3,484
    What is up with the BRAF table?
    OP you have the original unmodified tune file? Compared to the OE file I have yours has ALOT of stuff changed that shouldn't be, and a lot of jacked up shit otherwise.
    EFI specialist
    email=[email protected]
    Jun 2023
    18
    Hey mate I don't have the unmodified file as I brought the car already tuned but had problems so since been to 4 different tuners trying to sort out these problems, I just want to be able to drive my car and enjoy it
    Jun 2023
    18
    Quote Originally Posted by veSS View Post
    Thanks heaps mate il give it a try and do some data logs
    Jun 2023
    18
    okay so i tried them files above but got idle hunting and not starting great, ive decided to run my dctuning file as it starts and runs the best i just have a few little problems to sort out. #first idle seems abit rough and keep getting alot of timing swings on idle even though i cut down my adaptive idle settings alot and second thing i get weird surges sometimes on low rpm and at the same time see the timing move tables and last thing it feels a bit sluggish taking off but not that bad. here is the tune file and log
    cammed-ve-ss-manual-troy_DCTUNING_v7 (2).hpt
    dctuning-v7-datalog1 (1).hpl
    Jun 2023
    18
    here the tune file with spark adaptive cut down and a couple logs
    DCTUNING-Cammed Ve Ss Manual V1.hpt
    new idle log.hpl
    new log 1.hpl
    new log 2.hpl
    Aug 2006
    5BA8
    3,484
    It's still a train wreck. Why would your VE table go to 175 Kpa if the engine is normally aspirated? You can edit the X axis and you'd have great resolution.
    Why would you have +8/-8 degrees timing in your zero RPM error table?
    Why are the over/under tables so aggressive?
    It also looks like almost ALL of your idle adaptives have been modified.
    I suggest you pull a file off the repository, put most of everything back to stock.
    EFI specialist
    Aug 2009
    Calibrating
    3,378
    The tune is VERY rough? sorry 4 tuners have messed you over?
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Nov 2006
    2,875
    It would be better at this point to start from a completely stock file. Some dumb change someone made at some point could cause a lot of headache down the road.
    It's about impossible to just look at a tune and can tell if it's all stock unless you find an exact same OEM file.
    Tuner at PCMofnc.com
    Jan 2014
    Australia
    1,996
    this is best i can do to get back to stock so u can start fresh with some tables your ecu is same number as mine but mine is HSV LS2 so is slightly different with heads and stock camshaft but its close as i think u will get to a stock i just copied all from my stock over to yours
    Jun 2023
    18
    Okay mate thanks so best bet is to start from this file and catalog??
    Jan 2014
    Australia
    1,996
    if u want to use the SD tune then i went thru and setup as much as i could to be stock just fueling and some minor stuff i left, see how it goes, also change ur VE in scanner to suit the new layout, im not sure on actual fueling so make sure its good as ur testing not sure if u have WB or not
