Page 3 of 3 FirstFirst 123
Results 41 to 44 of 44
Thread: Getting back to tuning
  1. #41
    5BA8
    3,482
    Quote Originally Posted by 400Horses View Post
    Ah, I miss understood what you were explaining.
    I always make sure I fail on 1st for po101/2/3 so it gives me the SES on my dash when I am tuning the VE.
    When I am tuning the MAF I make sure the po101/2/3 are set to fail on 2nd so I don't get any codes while driving.
    You are telling me I need to turn off my max line pressures?
    When I re-enable the MAF and STFT and load the tune the line pressures drop and it doesn't shift as hard which I am ok with. It is the inconsistent shifting between 3-4 that I am concerned with. Because it doesn't do it when I am in SD tuning.
    The VE tuning LTFT+STFT 11 tune that you looked at should have the MAF failed for VE tuning. If it isn't I will have to check the tune when I have access to my laptop.
    Go to Trans diag. Set your max line pressure for DTC P0101/2/3 to disabled.
    Not sure how you misunderstood. It's pretty clear what I typed out.
    email=[email protected]
  2. #42
    Dec 2022
    Tennessee
    183
    I will look into it when I get back to my laptop. Thanks for the help.
  3. #43
    Dec 2022
    Tennessee
    183
    edcmat, I got it now. I was thinking about the engine diag. I had not done anything with the trans diag. so I honestly had not paid any attention to it. Sorry about the confusion.
    Disabling the line pressure will help with the firm shifts during my VE tuning, but other than that is it suppose to help anywhere else? I am ok with the hard shifts while tuning. I'm not doing any WOT pulls that would cause the trans to shift too hard.
  4. #44
    Dec 2022
    Tennessee
    183
    Tune and Scan with update
    Here is the latest tune with your updates to the tune and a scan that I did with the adjustments. I Also disabled the max line pressure in trans diag.
