Results 1 to 7 of 7
Thread: 1968 Camaro with Twin Turbo LS7 Tuning Help
    I have an LS7 with twin 369s, ID1300's, 9.7 to 1 compression and a T56 Transmission, I can give more specific details if needed. I've been tuning for a while, and think that I'm decent at it, but I'm struggling getting my car to run for more than a few hundred miles without fouling plugs and misfiring. One of the things that I was thinking is the issue is that my O2 sensors are after the turbo in the down pipe. Could I please get someone to look over my tune and let me know if they see anything that could be causing any issues?
    7,864
    How much pipe is there after the O2s? If they are too close to open air they will be false lean. And I sure hope there is at least one wideband being used somewhere in a setup like this and that it's been checked to make sure it's accurate. Though if the narrowbands are suspect and can't be used as a reference that will be pretty hard to do.
    You're using a MAF with this?? (why?)
    Cat Test & Post O2 test are still on, those are solely for the downstream sensors which are no longer there.
    Your injector data doesn't match the sheet I have for ID1300s but there's probably more than one variant... can you link to your exact injector or its datasheet?
    13,588
    You're fueling must be too rich while cruising if you are fouling spark plugs. Without a data log with a wideband, I can't really see how it's running.
    Aug 2006
    5BA8
    3,482
    The VE table is interesting that's for sure.
    MAF curve isn't the best either.
    Data log will tell you more than the tune file will. A tune file can't tell you what's going on.
    EFI specialist
    email=[email protected]
    7,864
    Nah dude, it's MAF-only, it doesn't even use VE.
    Aug 2006
    5BA8
    3,482
    LOL MMMk
    EFI specialist
    I will upload a log after this weekend, I?m military and will be working this weekend,
